Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
instability steel desig module
3 REPLIES 3
eusmor
554 Views, 3 Replies
Could you help me please?
I can’t understand why the elements 17 and 18 in the attachment have instability in the steel design module
David
3 REPLIES 3
Artur.Kosakowski
in reply to: eusmor
Because they are under  tension and exceeded the entered slenderness limit which in such case is calculated as for the entire length of the bar. I would suggest the changes as shown on the attached picture. Mind that this would also allow you to set the correct deflection limits.
Artur Kosakowski
eusmor
in reply to: Artur.Kosakowski
Then lateral buckling parameters doesn't work for tension members, only for compression members?
 please see atacment.
David
Artur.Kosakowski
in reply to: eusmor
Yes, this is correct however I'd say that the perpendicular beam(s)  is/are actually buckling restrains too and then they will be considered.
Artur Kosakowski
