robot detect an instability of tpe 2 in the node 128 (directione RZ). There aren't any mechanical instability of the structure so i don't know how to fix the problem. On-line guide doesnt'help me. How can i solve the problem?
Thanks in advance
Solved by Artur.Kosakowski. Go to Solution.
Definition of releases. I would block RX in the definitions of releases, check the results obtained for such model and address MX locally if needed. If you also block RZ in the definitions of the supports you will solve the instability issue.
