Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
instability ( of type 1) detected at some node in direct RY
6 REPLIES 6
huynhhoangvt
812 Views, 6 Replies
when i ran caculation model.It is appeared some problems.I can not solve it.How do i sovel these problems?What is method to solve these problems? Please advise and check it ! I had attach a file model below
6 REPLIES 6
huynhhoangvt
in reply to: huynhhoangvt
Please help me!
Rafal.Gaweda
Your model is inaccurate.
- slabs with diaphragms are not flat
- some columns are located in wrong planes
- some nodes on small roofs are loacted in fact 0,5-1cm above the roofs 310 312 367 368  282 284 373 374
- some nodes should be located in the same location , like 683 684 688
I do not understand idea of "hohn" release
To correct model :
- delete meshes
- run detailed correction to Structural Axes with tolerance 2cm
- corect nodes on the roofs
- correct location of bars  1203 1204 1327
- mesh model
- delete "hohn" releases from bars or correct them
Corrected model in the way described above attached.
Rafal Gaweda
huynhhoangvt
Thank you so much.I also have a question.Could you explain about a few methods such as " Newton- raphson iteration and BFGS iteration?When can i use these method?
huynhhoangvt
I have  fixed  model according to your guidline. But it is  appeared some problem when i ran calculation. I increased maximum number of BFGS corrections.  I can't  solve these problem.
Rafal.Gaweda
http://forums.autodesk.com/t5/forums/searchpage/tab/message?location=forum-board%3A351&q=newton+raph...
Rafal Gaweda
Rafal.Gaweda
Use Newton-Raphson
Corrected file attached
Rafal Gaweda
