Instability in beam
2 REPLIES 2
HoshangMustafa
237 Views, 2 Replies
Instability in beam
Hi Rafal
Please find the attached file. Why instability occurs while beam length is 15m and the section used is HEA600. How can I get rid of this instability. I supposed HEA400 will be OK.
2 REPLIES 2
Hi Rafal
Please find the attached file. When I choose 0.9 as the coefficint of length the section will be OK. What should I add to the model so that the beam will be stable?
The steel design code usually imposes limit on slenderness of a profile which is the function of its length. If you exceed it it is reported as instable profile. In such case you should increase the size of a beam despite the fact it is already large enough for applied load (strength verification).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
