Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Instability errors in model with no releases
9 REPLIES 9
Message 1 of 10
PaulGrimes2282
927 Views, 9 Replies
I have a model which was created by a colleague of mine and i've now taken over. It was giving instability errors, and i could not get rid of them so i went through and deleted all the releases but i was still getting instabilities.
Is there any common reason that this might happen? If not would someone be able to have a look at the model and see if they can find any errors in it that might be causing this? I will upload it somewhere if so.
thanks!
9 REPLIES 9
Message 3 of 10
Message 4 of 10
IN short - too many or wrong releases in some (many) nodes.
It will take me some  time to correct.
Rafal Gaweda
Message 5 of 10
Yes - i thought this might be the case. But when I removed all the releases I was still getting instability errors - is there some further underlying problem?
file with no releases:
https://www.yousendit.com/download/TEhYZm1kbThCMTd2WnRVag
Thanks for looking into it.
Message 6 of 10
Should I correct file with releases or not?
Rafal Gaweda
Message 7 of 10
merge nodes 796 1402
Rafal Gaweda
Message 8 of 10
Rafal.Gaweda
in reply to: Rafal.Gaweda
Model corrected http://wtrns.fr/oZNEZn3anfttNz - check diagrams etc.
I have removed some releases, new releases added : PP  and Fixed Pinned no rx ; nodes merged.
Rafal Gaweda
Message 9 of 10
Hello, thanks for your help so far. However when I open your fixed model and run it – I get a warning that says ‘Matrix is not positive definite’. This suggests that the model is unstable? (see image below)
<error1.PNG>
If I run the analysis with the DSC Algorithm turned on then I am still getting unstable nodes where they should be stable. (see image below)
<error2.PNG>
Is there any reason why this would be happening for me, but the model runs cleanly for you?
Thanks!
Message 10 of 10
Read the warning to the end ... check buckling.
Critical coeffs below 1 for nonlinear selfweight - check "upper branches of trees"
Rafal Gaweda
