Hello there, i am facing a problem in the analysis of a frame that contains a concrete column and a cantilever steel beam. when i run analysis a warning messege appears( instability at certain nodes).
This warning results in a high values of displacements
please find attached the fil.
Thanks in advance,
Ali
Your structure is unstable - releases are wrongly defined. Look below.
whats wrong with them??
and whats the correct way to define releases in this structure
the beam is cantilever and the upper point of the column is pinned
thank you in advance
Ali
Is is a mechanism = it is unstable.
fixed support + pinned release on column on the side of support = pinned support, no moment is blocked, no more supports, structure may collapse
cantilever beam released on one side, not supported on second -> mechanism -> collapse
tell me how this shoud work
Upper node of column is not supported at all.
