Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Instabilities
3 REPLIES 3
Franco.dipietro
207 Views, 3 Replies
Instabilities
I have a lot of displacement of node 97 but I can't understand the reason.
I have tried to use the DSC algorithm and the RLINK (because I have both releases and rigid link) but it is even worse.
I have attached the model for you to check.
Thank you very much
3 REPLIES 3
The reason seems to be the excessive number of releases. Personally I would initially remove them and then I would apply them in steps checking the behaviour of the structure. You may also want to merge nodes 17 and 24 which are very close to each other.
Artur Kosakowski
Thank you. I will try it.
For the algorithm, which one do you suggest? shall I also use the DSC + RLINK?
Have both switched off and try to use the Skyline solver.
Artur Kosakowski
