Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Inquiry about bridge modeling
14 REPLIES 14
Message 1 of 15
MUHANNAD.ABU_ABDO
639 Views, 14 Replies
I want to know how i can model hammerhead pier for bridge by using RSA 2014 & Also i want to know how i can make linear releases ...
many thanks
Eng.Muhannad
Muhannad M.Abu Abdo
Structural Design Engineer
14 REPLIES 14
Message 2 of 15
  1. Hello to all ...
  2. I want know if this is a true model for hammerhead pier or that's wrong way ..
  3. it's urgent ..
thanks
Muhannad M.Abu Abdo
Tags (1)
Message 3 of 15
1. hello
2. what's a hammerhead pier?
3. for your university assignment?
Message 4 of 15
A hammerhead pier from substructure elemnts in bridge .. i work on bridge project
Muhannad M.Abu Abdo
Message 5 of 15
tony.ridley
in reply to: tony.ridley
4. having looked at your model, this is not a good way to model a bridge pier.
5. it will be unstable, the only support is a single pinned support.
6. defining a solid object with a "tube" made of shell elements is not a good representation of the real life thing.
apart from that;
7. no mesh
8. no properly defined materials or thickness
9. no loads
Message 6 of 15
ya i know that .. there's no load cuz i want in the first to know how i can model hammerhead pier then i will exposed it to loads ... the questions is how i can model it as solid object .. can you tell me ?
Muhannad M.Abu Abdo
Message 7 of 15
can't just use a beam element?
Message 8 of 15
howi can use beam elemnt with diagonal shape ?? i tried but this also wrong ...
i know the solid object is right but i don't know how i can do it
Muhannad M.Abu Abdo
Message 9 of 15
Message 10 of 15
can you explain more about your idea ... if you don't  anyways thanks a lot
Muhannad M.Abu Abdo
Message 11 of 15
Thsi depends how detailed the design you want to make. You can see teh distribution of internal forces and stresses modelling it as a solid, a shell or a bar structure. For the latter two you can have theoretical are of reinforcement but you may not be able to have the detailed reinfoprcement distribution in the pier (especially in the head part).
You just indicate the edge you want to apply the release to
Artur Kosakowski
Message 12 of 15
Thanks a lot .. can you tell me how i can make hammerhead pier as solid object " some photos to more accurate understands " .. i will be gratefull to you
Muhannad M.Abu Abdo
Message 13 of 15
Try to draw a face and then extrude it.
Artur Kosakowski
Message 14 of 15
when i do it .. it's appear as hollow object not solid ? so what's the solution ?
Muhannad M.Abu Abdo
Message 15 of 15
What you did was the extrusion of lines (shell model) rather than a face (surface) created in a solid model type Smiley Happy
See: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Volumetric-structure-type/td-p/4408063
Artur Kosakowski
