Discussion Groups
Robot Structural Analysis
New Member
Tarrataca
Incorrect Data - Error Nr.5000
1128 Views, 17 Replies
01-30-2012 12:42 PM
During the calculation of a structural model (constitute only by bars elements), when in Buckling Deformation (Analysis Type), I switch off the option Omit case for structure with deformations, an error Nr. 5000 happens, and the calculation process is stopped. This error only happens in this situation, since the model is calculated normally when that option is on.
Is there any way of overpass this error ?
Best regards,
Tarrataca
Please use plain text.
Product Support
pp2008
Re: Incorrect Data - Error Nr.5000
01-31-2012 12:10 AM in reply to: Tarrataca
Error 5000 generally corresponds to memory problems.
If restarting Robot before running your model does not help please attach your model (compressed to ZIP to reduce its size) to check it in more detail.
Pawel Pulak
Product Support
pp2008
02-02-2012 06:18 AM in reply to: pp2008
The model was not attached but if it is the same case are reported via reseller then the reason is in using multi-threaded solver for this type of analysis. Please change to Automatic or Sparse in Tools>Job Preferences> Structure analysis
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Valued Contributor
jo2ny
09-24-2012 01:48 AM in reply to: Tarrataca
I got the same error, I read the discussion above, changed the analysys method to Sparse, and back to Automatic.
When set to Automatic, Robot just crashes. When set to Sparse, i get the 5000 error.
What can I do now?
I attached the model.
Thanks in advance
I'm running Robot x64 on Win 7 x64
Intel Core 2 Quad Q9640 @3.00 GHz
8 Gb Ram
Product Support
Rafal.Gaweda
09-24-2012 02:02 AM in reply to: jo2ny
Ionut
Change structure type on SHELL ; 3D frame with FEs can not be calculated as FRAME 3D structure.
Rafal Gaweda
Valued Contributor
jo2ny
09-24-2012 03:19 AM in reply to: Rafal.Gaweda
Yep, worked!
Thanks again for your swiftness and precission.
Amazing...
Member
kurniawanpp
07-24-2013 03:49 AM in reply to: jo2ny
I recently run an analysis but I've got the same error
I've tried to follow your suggestion above (changing the solver) but the result was still the same. What should I do?
Thanks a lot!
Product Support
Rafal.Gaweda
07-24-2013 03:59 AM in reply to: kurniawanpp
File please.
Rafal Gaweda
Member
kurniawanpp
07-24-2013 04:07 AM in reply to: Rafal.Gaweda
Please download the file via link below because the file is quite big
https://share.arup.com/ExPages/filedownload.cfm?FileID=91481249ku67885300ki40800690eg
Thanks for the help Rafal
Kurniawan
Product Support
Rafal.Gaweda
07-24-2013 06:00 AM in reply to: kurniawanpp
I should have been faster:
Rafal Gaweda
