Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Incorrect Data! - Error Nr.5000 in Harmonic analysis
4 REPLIES 4
398 Views, 4 Replies
Hello guys,
I want to do Harmonic and Harmonica FRF analysis. Did modal first, static cases are after modal analysis.
Tried  to change Automatic or Sparse in Tools>Job Preferences> Structure analysis, error still appears.
Any ideas?
I have attached my file.
4 REPLIES 4
Rafal.Gaweda
 harmonic analysis and cables.... Need to be fixed in software
You can replace cables by tension only elements (such model attached) or create proper time history case.
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks, Rafal,
But it didn't work anyway...
If I'm changing now static cases to Harmonic it calculates but doesn't provide any results N/A
And if I change static cases to FRF it brings the same Error 5000!
Whats wrong?
Rafal.Gaweda
...FRF and nolinearity....error 5000 corrected in 2014.
Workaround  make model linear or run several harmonic cases on model with tension only bars.
Rafal Gaweda
Thanks for advises. Downloaded RSA 2014.
