Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
davidgholmes
781 Views, 5 Replies
Incoherent Mesh
I am trying to model a multi storey concrete frame but am having difficulties meshing the structure when I add the upper stories, with a error message coming up saying there is an incoherent mesh on the edges. I have looked through other similar posts and have used the settings as this post: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Various-problems-on-mesh-generation/m-p/3764..., but I'm still having a problem in one area.
It seems to be only one element in a core wall at a floor that seems to be the problem as shown in the attached screen shot.
Any suggestions to get the model to analyse?
David
Tags (1)
5 REPLIES 5
Rafal.Gaweda
in reply to: davidgholmes
Freeze meshes \ panels and move node to get coherent mesh
PLease send us file to check it.
Rafal Gaweda
davidgholmes
in reply to: Rafal.Gaweda
Thanks Rafal,
The problem seemed to solve itself somehow, but seems to have come back now!
Which mesh were you suggesting to freeze? The slabs or the walls? I also don't seem to be able to select any of the nodes on the meshed wall to move?!
The model is bigger than the limit to send through this, can I email it to you?
Rafal.Gaweda
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
Rafal Gaweda
davidgholmes
Rafal.Gaweda
MOdel is so inaccurate....Wall panels are not defined in wall (shaft) planes, claddings not defined in wall planes.
I suggest to remodel them but there is one quick way to correct meshes.
Mesh model, freeze meshes \ panels (all) then move nodes to obtain coherent mesh.
Example movie:http://screencast.com/t/8zs7RganfTD9
Corrected this way model : https://www.filemail.com/dl.aspx?id=NUFPKMXHTOJASSS
Rafal Gaweda
