Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Incoherent data for apnels
11 REPLIES 11
Message 1 of 12
spspro
704 Views, 11 Replies
hello, than I am calculating required reinforcement of RC panels an error appears:
INCOHERENT DATA OF RC PANEL.
In the reinforcement table there are some nodes with errors, but forces in these nodes are not maximal.
I tried to change the reinforcement parameters, but it does not help.
What should I do? Can I ignore those errors and go to provided reinforcement of RC panels?
Does the errors have any influences in final results of required reinforcement?
Any advice, please
11 REPLIES 11
Message 2 of 12
Artur.Kosakowski
in reply to: spspro
You can check the values in the centers of the neighboring elements and use these values instead. Could you attach the model and indicate which panel to look at as well as what load cases you typed in ULS and SLS lists please? Thank you.
Artur Kosakowski
Message 3 of 12
spspro
in reply to: Artur.Kosakowski
My file is about 217MB size. How can I sent this file?
Message 4 of 12
Rafal.Gaweda
in reply to: spspro
Message 5 of 12
spspro
in reply to: Rafal.Gaweda
Please look at panel 1347. There are few nodes with error.
http://www.4shared.com/zip/YmfqtAXJba/VILNIUS_PANEL_1.html
Thank you
Message 6 of 12
Rafal.Gaweda
in reply to: spspro
With the settings like this:
And my file : http://www.filemail.com/d/hfkmulrcxzalymo I do not see any problems.
BTW I strongly recommend to correct file to get rid of instabilities.
Rafal Gaweda
Message 7 of 12
spspro
I do not understand, I just download your file and calculate it without any changes, and than I tried to calculate
panel No.1347 requied reinforcement the same error "INCOHERENT DATA FOR PANEL no. 1347" appears.
Maybe the problem is with may program version. I work with "Autodesk robot structural analysis professional 2013"
Message 8 of 12
Rafal.Gaweda
in reply to: spspro
Got it.
Just only in one node  17673.
Rafal Gaweda
Message 9 of 12
spspro
So, can I ignore it and provide reinforcement as in neighbors nodes, or should I do any correction in model??
Thank you
Message 10 of 12
Rafal.Gaweda
in reply to: spspro
Yes, ignore.
Rafal Gaweda
Message 11 of 12
spspro
OK, but if there are any possibilities to avoid this type of errors or it is just  something wrong with "Autodesk robot structural analysis professional"
Message 12 of 12
Rafal.Gaweda
in reply to: spspro
We need to fix soft 😞
Rafal Gaweda
