Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Improving the speed ofmy computer (hp Z800 workstation)
45 REPLIES 45
Message 1 of 46
Refaat
2807 Views, 45 Replies
Dear Sir
Can you help me to improve the performance of my computer(the speed), where I am doing dynamic analysis for concrete tower using (200 mode) , the finite element size(1.00m) on the version (ARSApro2013), whereas the program takes more than (60 hours) until I can get the analysis results.
Knowing that my compture(hp Z800 workstation) specifications as attached.Although , I've developed  it from (6 GB RAM) to (48 GB RAM) and don’t note any improvement in performance (increased speed).And the graphics card specifications as following :
GV-R795WF3-3GD
AMD Radeon HD 7950/PCI-E 3.0
3072 MB GDDR5/384 bit
Could  you guide me how to increase the efficiency of the computer (increase speed) or what way I can get the results of the analysis faster than (60 hours)?
Refaat
45 REPLIES 45
Message 2 of 46
Rafal.Gaweda
in reply to: Refaat
1. Send us model
2. Turn off saving quadratic combinations results in job preferences and check.
Rafal Gaweda
Message 3 of 46
Refaat
in reply to: Rafal.Gaweda
Dear Rafal
Attached is my model
Thanks in advance
Refaat
http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
Message 4 of 46
Refaat
Dear Rafal ? Attached is my model ? Thanks in advance Refaat ? http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
Message 5 of 46
Rafal.Gaweda
in reply to: Refaat
~5h25min
settings below
Rafal Gaweda
Message 6 of 46
Refaat
Dear Rafal
Even , I turn off saving quadratic option as you suggested but still my compture running since  more than 16 h ago.
So, what can I do ?
Thanks alot
Refaat
Message 7 of 46
Rafal.Gaweda
in reply to: Refaat
Log:
17:48:03 - Structure preparation for analysis #0
18:14:48 - End of preparation for analysis #0
18:14:48 - Start of analysis #0
18:14:48 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
The DSC algorithm option can be switched on in the 'Job preferences' dialog box (the 'Structure analysis' tab).
Do you want to continue? #0
18:44:19 - For 8 modes the mass participation factor is equal 70.19
Do you want to continue the increasing of modes?
[Press ESC to ignore all warnings] #0
18:49:56 - For 17 modes the mass participation factor is equal 76.66
18:56:46 - For 26 modes the mass participation factor is equal 76.70
19:04:45 - For 29 modes the mass participation factor is equal 86.65
19:13:57 - For 44 modes the mass participation factor is equal 87.23
23:38:36 - End of analysis #0
My comp:  HP z600
Rafal Gaweda
Message 8 of 46
Refaat
in reply to: Refaat
Dear Rafal
Do you have any other advice to overcome this problem ?
attached is basic information about my computer.
Refaat
Message 9 of 46
Rafal.Gaweda
in reply to: Refaat
PLease attache log file
"c:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\Tmp\robwin.log"
What happens after changing solver onto multithreaded ?
Rafal Gaweda
Message 10 of 46
Refaat
Dear Rafal
My computer is still runnig , once it finished I will send to u the (Log file ) and also I will try with multithreaded solver .
Also , I have noted that your computer has two processors while mine has only one.
Does this affect ?
Thanks alot
Refaat
Message 11 of 46
tony.ridley
in reply to: Refaat
If your computer is still too slow we can organise a swap!.
Message 12 of 46
Refaat
in reply to: tony.ridley
Hi Tony
Thank you for your interest , I agree but how ?
Regards
Refaat
Message 13 of 46
Rafal.Gaweda
in reply to: Refaat
Does this affect ?
I used Automatic solver = SparseM,so it does not matter.
Do not you have any "power saver" option on?
Rafal Gaweda
Message 14 of 46
Refaat
Dear Rafal
Sorry , What do you mean by " power saver "?
Refaat
Message 15 of 46
Rafal.Gaweda
in reply to: Refaat
Something like the option in notebooks : in case of no activity slowing down hard disk or diming screen....
Rafal Gaweda
Message 16 of 46
Rafal.Gaweda
MUltithreaded ~1h
14:44:28 - Start of analysis #1
14:44:28 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
Do you want to continue? #1
15:08:43 - For 8 modes the mass participation factor is equal 70.19
[Press ESC to ignore all warnings] #1
15:11:54 - For 17 modes the mass participation factor is equal 76.66
15:15:27 - For 26 modes the mass participation factor is equal 76.70
15:19:20 - For 29 modes the mass participation factor is equal 86.65
15:23:37 - For 44 modes the mass participation factor is equal 87.23
15:41:05 - End of analysis #1
Rafal Gaweda
Message 17 of 46
Refaat
Dear Rafal
Good morning
First Trial
It has been done under the following conditions :
 -  turn off the display (10 min) .
-  Method of solving (Automatic) .
- Save results of quadratic combination (Active)
I got the results after  77h16min , and I got the percent of mass participation more than (90%) after 168 mode .
  Second Trial (pls ,sse shot 02)
It has been done under the following conditions:
- Turn off the display (never)
- Method of solving (Multi- threaded )
- Save results of quadratic combination (Not active)
I got the results after 2h28min , and I got the percent of mass participation more than (90%) after 127 mode.
My Inquiries are :
1 . Do you agree with me that the processor affect  the calculation speed as it appears after comparing the time calculation  between us using multi-threaded solver?
 2. why  does the number of modes decreased in multi-threaded?
Thanks alot
Refaat
Message 18 of 46
Rafal.Gaweda
in reply to: Refaat
IN case of multithreded solver- yes - you can compare yours and mine times.
IN auto \ SparseM sover the times should be comparable
I will check
Rafal Gaweda
Message 19 of 46
Rafal.Gaweda
I think you are working on different models.
It is enough to run 50 modes on mine : http://www.4shared.com/zip/r9UILvSV/Strucutral_meshed1.html
Rafal Gaweda
Message 20 of 46
Refaat
Dear Rafal
Actually , I am working in the same model but the settings are different.
I have noted that when I activated (inactive) in (model analysis parameter ) then I need to use more number of modes than if I activated (percent of mass participation ) to get (90%)
Do you agree with me or there is any another opinion
I appreciate your good cooperation
Refaat
