Discussion Groups
Robot Structural Analysis
Product Support
1,303 Kudos
Re: Improving the speed ofmy computer (hp Z800 workstation)
11-12-2012 04:31 AM in reply to: refaat
If possible please attach screen shot with your Modal analysis settings.
Maybe you use different  method or ...
Rafal Gaweda
Distinguished Contributor
4 Kudos
11-12-2012 07:06 AM in reply to: Rafal.Gaweda
Dear Rafal
Attached is the screen shot with modal analysis parameters
Thanks alot
Refaat
Product Support
1,303 Kudos
11-13-2012 06:33 AM in reply to: refaat
Thanks, developers are checking it.
Rafal Gaweda
4 Kudos
11-17-2012 11:30 PM in reply to: Rafal.Gaweda
Dear Rafal
  I am still working  on the same model . But I couldn't  able to get participation (90%) when I used the fixed supports under columns & walls instead of the raft foundation with springs.
Pls, Could you help me to get (90%) ? , attached is my model with fixed supports .
http://www.2shared.com/file/l-2ZjR1X/Strucutral_meshed1_fixed_suppo.html
Thanks a lot
Refaat
Product Support
1,303 Kudos
11-19-2012 03:29 AM in reply to: refaat
1. Selweigtht as mass for modal analysis duplicated in your model (1: from modal analysis settings, 2: load to mass conversion)
2. Results for such settings:
Rafal Gaweda
Product Support
1,303 Kudos
11-19-2012 07:17 AM in reply to: Rafal.Gaweda
Different settings:
Rafal Gaweda
4 Kudos
11-19-2012 10:40 PM in reply to: Rafal.Gaweda
Dear Rafal
Pls , Could you resend both of the screen shot , because they don't  appear on my computer.
Thanks a lot
Refaat
Product Support
1,303 Kudos
11-20-2012 12:12 AM in reply to: refaat
Rafal Gaweda
4 Kudos
11-20-2012 01:03 AM in reply to: Rafal.Gaweda
Dear Rafal This duplicated (mass of self weight) can be happened only when I have fixed supports ? if your answer (No) , pls , can you show me how can I know there is any duplicated in my model ? Thanks a lot Refaat
Product Support
1,303 Kudos
11-20-2012 02:13 AM in reply to: refaat
See below:
Rafal Gaweda
