Improving the speed ofmy computer (hp Z800 workstation)
45 REPLIES 45
Message 1 of 46
Refaat
2850 Views, 45 Replies
Dear Sir
Can you help me to improve the performance of my computer(the speed), where I am doing dynamic analysis for concrete tower using (200 mode) , the finite element size(1.00m) on the version (ARSApro2013), whereas the program takes more than (60 hours) until I can get the analysis results.
Knowing that my compture(hp Z800 workstation) specifications as attached.Although , I've developed  it from (6 GB RAM) to (48 GB RAM) and don’t note any improvement in performance (increased speed).And the graphics card specifications as following :
GV-R795WF3-3GD
AMD Radeon HD 7950/PCI-E 3.0
3072 MB GDDR5/384 bit
Could  you guide me how to increase the efficiency of the computer (increase speed) or what way I can get the results of the analysis faster than (60 hours)?
Refaat
45 REPLIES 45
Message 2 of 46
Rafal.Gaweda
in reply to: Refaat
1. Send us model
2. Turn off saving quadratic combinations results in job preferences and check.
Rafal Gaweda
Message 3 of 46
Refaat
in reply to: Rafal.Gaweda
Dear Rafal
Attached is my model
Thanks in advance
Refaat
http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
Message 4 of 46
Refaat
Dear Rafal ? Attached is my model ? Thanks in advance Refaat ? http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
Message 5 of 46
Rafal.Gaweda
in reply to: Refaat
~5h25min
settings below
Rafal Gaweda
Message 6 of 46
Refaat
Dear Rafal
Even , I turn off saving quadratic option as you suggested but still my compture running since  more than 16 h ago.
So, what can I do ?
Thanks alot
Refaat
Message 7 of 46
Rafal.Gaweda
in reply to: Refaat
Log:
17:48:03 - Structure preparation for analysis #0
18:14:48 - End of preparation for analysis #0
18:14:48 - Start of analysis #0
18:14:48 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
The DSC algorithm option can be switched on in the 'Job preferences' dialog box (the 'Structure analysis' tab).
Do you want to continue? #0
18:44:19 - For 8 modes the mass participation factor is equal 70.19
Do you want to continue the increasing of modes?
[Press ESC to ignore all warnings] #0
18:49:56 - For 17 modes the mass participation factor is equal 76.66
18:56:46 - For 26 modes the mass participation factor is equal 76.70
19:04:45 - For 29 modes the mass participation factor is equal 86.65
19:13:57 - For 44 modes the mass participation factor is equal 87.23
23:38:36 - End of analysis #0
My comp:  HP z600
Rafal Gaweda
Message 8 of 46
Refaat
in reply to: Refaat
Dear Rafal
Do you have any other advice to overcome this problem ?
attached is basic information about my computer.
Refaat
Message 9 of 46
Rafal.Gaweda
in reply to: Refaat
PLease attache log file
"c:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\Tmp\robwin.log"
What happens after changing solver onto multithreaded ?
Rafal Gaweda
Message 10 of 46
Refaat
Dear Rafal
My computer is still runnig , once it finished I will send to u the (Log file ) and also I will try with multithreaded solver .
Also , I have noted that your computer has two processors while mine has only one.
Does this affect ?
Thanks alot
Refaat
Message 11 of 46
in reply to: Refaat
If your computer is still too slow we can organise a swap!.
Message 12 of 46
Refaat
Hi Tony
Thank you for your interest , I agree but how ?
Regards
Refaat
Message 13 of 46
Rafal.Gaweda
in reply to: Refaat
Does this affect ?
I used Automatic solver = SparseM,so it does not matter.
Do not you have any "power saver" option on?
Rafal Gaweda
Message 14 of 46
Refaat
Dear Rafal
Sorry , What do you mean by " power saver "?
Refaat
Message 15 of 46
Rafal.Gaweda
in reply to: Refaat
Something like the option in notebooks : in case of no activity slowing down hard disk or diming screen....
Rafal Gaweda
Message 16 of 46
Rafal.Gaweda
MUltithreaded ~1h
14:44:28 - Start of analysis #1
14:44:28 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
Do you want to continue? #1
15:08:43 - For 8 modes the mass participation factor is equal 70.19
[Press ESC to ignore all warnings] #1
15:11:54 - For 17 modes the mass participation factor is equal 76.66
15:15:27 - For 26 modes the mass participation factor is equal 76.70
15:19:20 - For 29 modes the mass participation factor is equal 86.65
15:23:37 - For 44 modes the mass participation factor is equal 87.23
15:41:05 - End of analysis #1
Rafal Gaweda
Message 17 of 46
Refaat
Dear Rafal
Good morning
First Trial
It has been done under the following conditions :
 -  turn off the display (10 min) .
-  Method of solving (Automatic) .
- Save results of quadratic combination (Active)
I got the results after  77h16min , and I got the percent of mass participation more than (90%) after 168 mode .
  Second Trial (pls ,sse shot 02)
It has been done under the following conditions:
- Turn off the display (never)
- Method of solving (Multi- threaded )
- Save results of quadratic combination (Not active)
I got the results after 2h28min , and I got the percent of mass participation more than (90%) after 127 mode.
My Inquiries are :
1 . Do you agree with me that the processor affect  the calculation speed as it appears after comparing the time calculation  between us using multi-threaded solver?
 2. why  does the number of modes decreased in multi-threaded?
Thanks alot
Refaat
Message 18 of 46
Rafal.Gaweda
in reply to: Refaat
IN case of multithreded solver- yes - you can compare yours and mine times.
IN auto \ SparseM sover the times should be comparable
I will check
Rafal Gaweda
Message 19 of 46
Rafal.Gaweda
I think you are working on different models.
It is enough to run 50 modes on mine : http://www.4shared.com/zip/r9UILvSV/Strucutral_meshed1.html
Rafal Gaweda
Message 20 of 46
Refaat
Dear Rafal
Actually , I am working in the same model but the settings are different.
I have noted that when I activated (inactive) in (model analysis parameter ) then I need to use more number of modes than if I activated (percent of mass participation ) to get (90%)
Do you agree with me or there is any another opinion
I appreciate your good cooperation
Refaat
