Discussion Groups
Robot Structural Analysis
Distinguished Contributor
refaat
Improving the speed ofmy computer (hp Z800 workstation)
819 Views, 45 Replies
11-04-2012 11:30 PM
Dear Sir
Can you help me to improve the performance of my computer(the speed), where I am doing dynamic analysis for concrete tower using (200 mode) , the finite element size(1.00m) on the version (ARSApro2013), whereas the program takes more than (60 hours) until I can get the analysis results.
Knowing that my compture(hp Z800 workstation) specifications as attached.Although , I've developed  it from (6 GB RAM) to (48 GB RAM) and don’t note any improvement in performance (increased speed).And the graphics card specifications as following :
GV-R795WF3-3GD
AMD Radeon HD 7950/PCI-E 3.0
3072 MB GDDR5/384 bit
Could  you guide me how to increase the efficiency of the computer (increase speed) or what way I can get the results of the analysis faster than (60 hours)?
Refaat
Please use plain text.
Product Support
Rafal.Gaweda
Re: Improving the speed ofmy computer (hp Z800 workstation)
11-05-2012 12:33 AM in reply to: refaat
1. Send us model
2. Turn off saving quadratic combinations results in job preferences and check.
Rafal Gaweda
refaat
11-05-2012 06:37 AM in reply to: Rafal.Gaweda
Dear Rafal
Attached is my model
Thanks in advance
Refaat
http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
refaat
11-05-2012 07:34 AM in reply to: Rafal.Gaweda
Dear Rafal ? Attached is my model ? Thanks in advance Refaat ? http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
Product Support
Rafal.Gaweda
11-05-2012 11:29 PM in reply to: refaat
~5h25min
settings below
Rafal Gaweda
refaat
11-06-2012 03:23 AM in reply to: Rafal.Gaweda
Dear Rafal
Even , I turn off saving quadratic option as you suggested but still my compture running since  more than 16 h ago.
So, what can I do ?
Thanks alot
Refaat
Product Support
Rafal.Gaweda
11-06-2012 05:10 AM in reply to: refaat
Log:
17:48:03 - Structure preparation for analysis #0
18:14:48 - End of preparation for analysis #0
18:14:48 - Start of analysis #0
18:14:48 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
The DSC algorithm option can be switched on in the 'Job preferences' dialog box (the 'Structure analysis' tab).
Do you want to continue? #0
18:44:19 - For 8 modes the mass participation factor is equal 70.19
Do you want to continue the increasing of modes?
[Press ESC to ignore all warnings] #0
18:49:56 - For 17 modes the mass participation factor is equal 76.66
18:56:46 - For 26 modes the mass participation factor is equal 76.70
19:04:45 - For 29 modes the mass participation factor is equal 86.65
19:13:57 - For 44 modes the mass participation factor is equal 87.23
23:38:36 - End of analysis #0
My comp:  HP z600
Rafal Gaweda
refaat
11-06-2012 10:45 PM in reply to: refaat
Dear Rafal
Do you have any other advice to overcome this problem ?
attached is basic information about my computer.
Refaat
Product Support
Rafal.Gaweda
11-07-2012 12:21 AM in reply to: refaat
PLease attache log file
"c:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\Tmp\robwin.log"
What happens after changing solver onto multithreaded ?
Rafal Gaweda
refaat
11-07-2012 12:59 AM in reply to: Rafal.Gaweda
Dear Rafal
My computer is still runnig , once it finished I will send to u the (Log file ) and also I will try with multithreaded solver .
Also , I have noted that your computer has two processors while mine has only one.
Does this affect ?
Thanks alot
Refaat
