Improve flexural, torsional, flexural-torsional, lateral-torsional buckling analysis in steel beams, adding Warping torsional degree of freedom for steel beams.
There are some software (STABLAB, SOFISTIK) use a beam finite element directly developed for the analysis of thin-walled spatial steel members. This element is based on Vlasov theory and has 7 degree of freedom at each node (3 displacements, 3 rotations and 1 warping freedom). You don't need to built a model based in shell elements to realize the buckling analysis of the steel profiles.
