some time ago I created a model which had sections done with "section definition" tool and some fabricated sections done using the standard bar sections tab.
I cannot find the database where the section drawn in "section definition" where saved, but these remain in the model. Is it possible to used them in a different model? how could i do that?
Thank you,
sanjuan100
Solved by pipiyedu. Go to Solution.
Hi
Use Section definition>> Save to section database
Please find the attached file.
