Import Nodes from a Spreadsheet??
5 REPLIES 5
AndyWalker
963 Views, 5 Replies
Hello Everyone i hope you can help.
I was wondering is it possible (and if so how) to import nodes from a spreadsheet?
I have a spreadsheet with all the node coordinates and was hoping to use this to construct a steel frame.
Any help would be most gratefully recieved!
thanks
ANdy
5 REPLIES 5
rsousa_
in reply to: AndyWalker
You should see this example_:
http://www.robobat.fr/n/ros/662/
The code should be like this (if you have a list of node coordinates in column A, B and C)
Dim Robot As Object
Set Robot = CreateObject("Robot.Application")
Dim nods As Object
' --- create nodes
Set nods = Robot.Project.Structure.Nodes
For i = 1 To n + 1
  nods.Create i, cells(i,1), cells(i,2), cells(i,3)
Next i
Set Robot = Nothing
End Sub
Hope this can help you!
Regards
Pawel.Pulak
The simplest way is to use Copy&Paste on Edit tab of the table of nodes. As in this video.
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
AndyWalker
in reply to: Pawel.Pulak
thank you both for your replys,
for some reason i cant get that video to work. am i being stupid?
thanks
Pawel.Pulak
Direct link to video: http://screencast.com/t/kfqh59S4s
If not working in one browser try another.
Pawel Pulak
AndyWalker
thank you!!
