Hi there,
I need to create a large complex model of an indutrial facility in Robot.
I am thinking in doing this first in a different programme and later import this into Robot to analyze it.
The first questions I have would be:
1) It's a frame model so, I could build the lines say in Autocad, and create from this a Robot model.
2) How can I give properties to this lines so on when I import this in Robot it comes with the right section sizes, materials, ( even release properties?), etc.
Is there a way to link a table (in Excel maybe) with the section, materials, etc properties and a geometrical model?
Any information would be greatly appreciated, thanks in advance.
Sanjuan100
Hi Artur,
Thanks for your prompt response! However, I'm not familiarize with ASD, is there a different way of importing drawings that have attached properties to their elements?
Thank you.
sanjuan100
Hello again,
in the lines of this discussion is there a way for a table import of the structural axis? For instance from a table created in Excel?
Thanks again!
sanjuan100
ASD(autocad structural detailing) steel is just autocad on "Steelroids" !
Rafael Medeiros
Thanks Rafacascudo,
but isn't it ASD a much more complete programme? Meaning whether it is model and detail a steel structure, producing shop/fabrication drawings, etc?
I don't understand what's the advantage of doing this in ASD to doing it in Robot from the beginning?
I've got to model a structure, which is large and has several section types and properties (rolled, welded, pinned/fixed connections, etc.) and needed to introduce this information in Robot in a efficient and organized manner to avoid errors and deal quickly with potential changes.
trying to keep it simple i was looking to create a wireframe dxf/dwg of the bars in autocad or similar and later give properties to this bars from a table in Excel? I guess this is sth that can be done independently (the wireframe and the table)?
On the other hand, is there a way of doing the structural axis without using the tool in Robot where you introduce them one by one?
Thank you very much,
sanjuan100
For your objective you may use ASD Steel in the same way as you work with AutoCAD. Just draw a line (in this case a center line of a selected profile shape) from its origin to its end locations. Then export the model to Robot where you can assign supports and releases. Both programs share the same section databases.
Stefano ,
Why advance steel is not good with Robot. How do you compare the 2 softwares (advance steel and ASD) integration with Robot?
thx!
Rafael Medeiros
Thank you all,
but please could you reply to?
1) Is it possible to define a structural grid from excel table or similar? and how?
2) is it possible to introduce section properties using a method different to the bar sections tab?
All the above without using ASD please.
sanjuan100
Hi all,
in reply to sanjuan100,
1) the attached API via excel give you the opportunity to create structural axes via excel;
2) there are many ways to import your model, it depend by the size and the number of structural member. For example you can save many *.dxf files, one for cross section type and import one by one in robot and then join them. Or you can save only one *.dxf layered by cross section and move all the layers of (for example) 100mm, import this model in robot, assign to the uniform zones the cross section and then move the bars in the correct position....All it depend by the composition of your model...if you share the cad model we can give you more suggestions.
Hi Rafacascudo,
my opinion about Advance Steel is not bad, but the productivity between Robot and ASD is not replaceable, when you set ASD in the right way it become a very powerful tool to work. I agree with you that Advance Steel is much better than ASD (...specially for large models...) but with it you can't make the "same sharing" that you have with ASD.
After years I've very well learned ASD and now I really appreciate it!!!
Greetings at all
Rafael Medeiros
This is basic question now:
To import dxf/dwg files, this needs to be done from the "open" menu right? But everytime you "open" a dxf/dwg it creates a new file. Can't you not add from dxf/dwg?
Stefano,
Thanks very much for your response and for the API. I can't send a CAD model through since this is a structure done 30 years ago, drawing are not done using CAD but hand made 😮
Re ASD, I've got several section sizes from standard european and british UC, to fabricated I sections and girders and most complicated in the model - column sections with additional cover plates..
is this something I can easily do/introduce in the programme ASD?
Thanks a lot,
sanjuan100
If you save them in the Robot user section database you will be able to use them in ASD Steel too (meaning you can use them in ASD and have them recognized in Robot when you export a model from ASD to Robot). Standard sections such as UC or European are available by 'default'.
HI
I think that the answer is NO.
Greetings
hi Stefano & All,
Using the AddIn for grid generation I'm seeing the API considers the units of the spreadsheet in 'm' and converts them to whatever you have in the model ('ft' in my case).
Is this correct? is there a way to change it? I'd like to introduce values in my project units if this is possible.
sanjuan100
