Discussion Groups
Robot Structural Analysis
111 Kudos
IMPORT AND EXPORT FROM ASD TO ROBOT
5175 Views, 8 Replies
10-18-2012 08:51 AM
Hi everyone, I have a problem with the import and export models from asd to robot. Last week I've uninstalled ASD2012, robot 2010 and robot 2011 from my pc and now I can't import or export any model.
Anyone can say me how I can fix this issue without reinstall all?
Thanks a lot. bye
PasProStudio
Structural + Detailing engineers
Product Support
760 Kudos
Re: IMPORT AND EXPORT FROM ASD TO ROBOT
10-19-2012 12:09 AM in reply to: StefanoPasquini6790
I assume that you want to work with  ASD 2013 and Robot 2013.
Try to start ASD and close it. Then register Robot (from Start menu) using the option indicated below running is as admin (available under the RMB):
Artur Kosakowski
111 Kudos
10-19-2012 01:42 AM in reply to: Artur.Kosakowski
Good morning Artur, I'm sorry but it doesn't work. I tried to do everything you say, but the result was the same.
There is any win register key that i can modify to run correctly the ASD to Robot transfer.
Thanks a lot.
PasProStudio
Product Support
760 Kudos
10-19-2012 02:06 AM in reply to: StefanoPasquini6790
Start Command Prompt as Admin (from rigth hand mouse menu) then unregister and register Robot
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /unRegServer
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /RegServer
Check the picture from the message 6 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-error/m-p/3518984/ that shows similar procedure for a dll file.
Artur Kosakowski
111 Kudos
10-19-2012 02:48 AM in reply to: Artur.Kosakowski
Many many thanks for your easy and quick solution. You are the best...
Grating
PasProStudio
Distinguished Contributor
3 Kudos
06-29-2013 02:38 AM in reply to: StefanoPasquini6790
Dear All
Please check for me file slab area from ROBOT in ASD
My file
http://www.mediafire.com/?gr6v7x879tfm7sb
Thanks all
Product Support
760 Kudos
07-01-2013 02:01 AM in reply to: duchoabn
You should use either the bar surface reinforcement or wire fabrics and manually generate reinforcement distribution based on the values of area imported from Robot.
Artur Kosakowski
Valued Mentor
97 Kudos
09-12-2014 09:26 AM in reply to: Artur.Kosakowski
Is it possible to export from Robot 2015 to ASD 2014?
111 Kudos
09-12-2014 09:46 AM in reply to: Rafacascudo
I think that the answer is yes. I've installed ARSA 2015 many time before to install ASD 2015, and in this time I've exported ARSA 2015 model to ASD 2014 or 2013.
Greetings
PasProStudio
