Hi
How can I import a panel structure?, Which type of Autocad element should be (3D face, Region, Mesh)?
Solved by Artur.Kosakowski. Go to Solution.
Try to import the outer boundaries of panels. You can import them as bars and use them to create panels either by indication a point inside such created contour or by selecting them during a panel definition. After creating panels they can be selected and deleted from the model.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
