Help cant import a dxf from cbs to robot error message : error lors du chargmenet du fichier
Solved by Artur.Kosakowski. Go to Solution.
What is the reason for this if I may ask? Mind that you can send the model directly from CBS to Robot.
The error message is " error while importing the file " .I need to import the dxf to ROBOT so i can merge it with another structure already modeled on Robot. sorry for my english
Try the following:
1. Open CBS model you want to export to Robot in CBS
2. Export it to Robot (Tools > Export to the Robot program commands)
3. Having the exported model opened in Robot use Geometry > Structure > Import from file > select rtd file type > indicate the 'structure already modelled in Robot' file.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
