Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Huge deflections
3 REPLIES 3
bartosz_borowiak
692 Views, 3 Replies
Huge deflections
I just run an analysis and got very weired results. Deflection is about 5mm at the end and about 6200 in the mid span of some beams ( see pic attached) I checked gemotery and relaeases and node looks ok. Any ideas?
File
3 REPLIES 3
Correct model first to get rid of instabilities
Rafal Gaweda
dimogrec
in reply to: bartosz_borowiak
You have too many bar releases -> big number of degrees of freedom
Also avoid bar releases on pinned base. Example in picture : pinned base by definition has free Rx,Ry,Rz so you don't need to release also the bar (bracing) edge
Tags (2)
bartosz_borowiak
in reply to: dimogrec
Thank you so much.
