I just run an analysis and got very weired results. Deflection is about 5mm at the end and about 6200 in the mid span of some beams ( see pic attached) I checked gemotery and relaeases and node looks ok. Any ideas?
Solved by dimogrec. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
You have too many bar releases -> big number of degrees of freedom
Also avoid bar releases on pinned base. Example in picture : pinned base by definition has free Rx,Ry,Rz so you don't need to release also the bar (bracing) edge
