Hello everybody, i'm a new member and i'm reseaching about Robot. But i don't know how to write addin. I just found a clip write addin for Revit. In clip, i see he use 2 file are RevitAPI.dll and RevitAPIUI.dll. But in Robot, i didn't found anything like that. Just a file is "rcuapi.dll" in link "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\RESC" Can you help me ?
Thanks you so much .
https://www.youtube.com/watch?v=PqgyeQDzGak
Thanks you so much Rafal.Gaweda. I'm so lucky to be get your help.
Can you help me to make a " hello world " project. i'm not still understand how to make it. Thanks you
What do you mean by that? Movie shows everything.
sorry you, i'm a newbie. everything is new to me.
If i want to process results tables, i can use how is command ?. In fact, my teacher give me a exercises, he said me find the way ( the codes ) to take all result in one turn. all results in one table. It's not to see. Essence is he want import that datas ( all result ) to other programs.. The data is full and enought, i just call it one turn and do with.. That's it all i want you help me, thanks you
Dump all tables you want to text files (csv) then merge them into one file or generate text file in required format by your own using Robot API.
