As the title says how can you show the moment equation for the moment diagrams?
If you mean the formula used to calculate a value of bending moment in a given point then it is not possible.
Hi
How to show the moment equation for the moment diagrams
I think you mean showing negative moment coefficients at the ends and positive moment coefficients at the middle (like ACI coefficients for beams and one way slabs, or moment coefficients for Diret Design Method and Equivalent Frame Method) in the analysis module.
Autodesk Robot Structural Analysis uses matrix methods (finite element methods) to analyze the structure. So it uses stiffness matrices, load matrices and material matrices to find displacements and then finding forces in the members.
If you mean showing design equations (e.g, equations for designing a beam according to ACI code, for shear for flexure, for torsion, etc..
or designing a steel beam according to AISC)
then ARSA shows these equations in the calculation notes.
