Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
How to reverse Column behavior
4 REPLIES 4
aliyuaziz
434 Views, 4 Replies
How do I tell Robot to design the middle column to take the load from the lower floor and transfer to the beam at roof level?
Best regards,
Aliyu A. Aziz
4 REPLIES 4
HoshangMustafa
in reply to: aliyuaziz
Hi
Please model it as a bar instead of a column.
aliyuaziz
in reply to: HoshangMustafa
Thanks Mustafa,
I have changed the member type to a simple bar. What would inform me that the bar is transfering load upwards? Thanks a lot for your guidance.
Best regards,
Aliyu A. Aziz
Rafacascudo
Check the middle columm axial force .If it is in tension , then , it is transfering the load to the upper beam.
If you don´t want to transfer the load to the lower beam , make it tension only bar on Geometry/additional atributes/Advanced bar properties or in Geometry/Releases if you still want the columm to carry moments and shears forces.
Rafael Medeiros
aliyuaziz
in reply to: Rafacascudo
Dear Rafacascudo,
Many thanks for your guidance, I am really grateful.
Best regards,
Aliyu A. Aziz
