I am getting 'For panel no. 71 the minimum bar spacing: 4.0 [cm] < 4.5 [cm] is exceeded.' error message. Any guidance on how to resolve it?
Any verification results for flat slab design to compare with that of robot?
Thanks a lot.
Aziz
Solved by Artur.Kosakowski. Go to Solution.
Increase rebar sizes to allow for larger spacing for the same area of reinforcement or increase panel thickness to reduced required are of reinforcement.
