hey
i would like to know how to orient a bar so then i can introduce the releases on them?
i would appreciate some help, im new at robot
thank you all
Solved by Rafal.Gaweda. Go to Solution.
Geometry/properties/Gama angle...
Rafael Medeiros
Just as Rafacascudo suggested, do the following:
http://www.screencast.com/t/9FjXZ7WYfaK
sorry to bother you but I still have a doubt about this. I have tried to change this one the gamma angle and I saw the axis changing but when I click on a bar depending if its on a side or another there it shows different orientation (as you can see on the attachments).
By the way I notice that one of u its called teixeirinha (i´m portuguese if it makes it easier)
This is "temporary" LCS for assigning some properties graphically
See example:
