I am analysing a Davit Crane used on offshore rigs.
I have a piep (pipe2) going inside another pipe (pipe1). Pipe2 is free to rotate 360 degrees. Pipe1 is stationary.
How to model this pipe in pipe configuration ?!
Solved by Pawel.Pulak. Go to Solution.
If you release RX rotation on Pipe 2, structure becomes unstable.
Rafael Medeiros
You will loose the weight and the increased Inertia if they are connected horizontally(Ux,Uy).
Maybe you can create a custom section( tools/ section definition) with the 2 tubes. Never done , don´t know if it´s possible.
Another option is creating a generic section Ax,Iy,Iz...( last tab on " new section) with the properties you want for the section.But you lose the graphic representation
- Another one is create a tube section in tolls /section definition send it to user database and edit its properties on tools / section database.
if your problem is really only the weight you can create a material with an increased "Force density"
Rafael Medeiros
Why not using a linear (local OX) force to model that weight?
My 5 cents to discussion:
in case of applying load as shown picture you can ignore RZ rotation of top part
simplified model : top part as it is; bottom part assumtion: no clearence between pipes -> custon circular section with inner diameter = inner diameter of P2 and outer diameter = outer diameter of P1
model as described above by Stefano - beacause of rigid links the assumption will be the same as above : no clearence between pipes
model as described above by Stefano - but WITH clearence between pipes -> rigid links should be replaced by "rigid bars" with gap releases
In none of these approaches you will loose weight.
Below is the wroking schematics intended.
I can not model a single circular section for the bottom part, as there is a gap between the pipes.
Hi
You can use two free body diagrams:
analysing one free body diagram for the forces for the inner pipe
inserting the forces (got from the analysis of inner pipe) to the free body diagram of the outer pipe
It is possible to use overlapped bars in Robot and to model such crane using them but it is necessary to model it in the appropriate way.
Your drawing suggests that the internal (small) pipe at the bottom is connected in the continuous way with the big top pipe.
Moreover he internal (small) pipe at the bottom is placed inside the bottom big pipe, which is fixed at the bottom.
The inner and outer pipes make contact only at their ends (clearance between the pipes).
It is not clear where the inner pipe is supported vertically - I have assumed that at the bottom.
See this video:
Attached the model corresponding to it.
The main modeling steps visible on the video:
As you can see step 7. resulted in stopping to display the verification error related to overlapped bars - Robot "guessed" that it is an intended action.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
