Hello everyone! Please tell me is there a way to copy those loads that have been already assigned. I mean to select and click copy or maybe some commands which work with a load table. It would be much easier and faster to edit those loads that have been already assigned.
Solved by Rafal.Gaweda. Go to Solution.
It depens on loads you used but in general go to Loads table, mark row or rows with loads, CTRL+C, highligh the last record in this tabble (the one with *), CTRL+V, then adjust pasted records
and graphically? may be using right-click by the element?
Toghether with element.
so you state that this connection is bidirectional: by selecting an element in a table it will be also selected on the display? Do I understand it right?
IN the table you can see many objects numbers in List cells. So if you copy whole record loads to all of them will be copied. But in general yes unless you turn off synchronizations between tables and views in preferences.
To work faster, we have 2 same models, and we assign Load for each story, why can't i copy the load from load table from the model to the other one? Please help me! Thanks
You can copy but loads are applied to certain objects \ elelemnts numbers. So if the numberation is different some loads can not be applied or can be applied to elements located in different places but having correct numbers as defined in load list
Thank you for your response, but the problem is we have the same model, that means the elements and their coordinates are the same, but when i copy from the one to the orther, the value of load is zero?
Bars numbers, nodes numbers, panels, claddings numbers are important , not their coordinates.
But i define load by load on contour, that means the position of load will define by coordinate of points not by any element, please make me clear! Thanks
