Also in "Geometry" menu and in all other menus, then I click "load definition", doasn't matter what I will choose node / bar / surface, when I clck "delete the selected load type" and click on the element or writing elements number in "apply to" section and clicking "apply" doesn't do anything. This happens on all my projects since I have started using Robot.
Analogical function (delete) for deleting supports or releases working without problems....
Anyone else hasthis problem? Maybe there is a solution for this?
Solved by Rafal.Gaweda. Go to Solution.
Example 1: http://screencast.com/t/37ixxrqgvM4U
Example 2: http://screencast.com/t/vV9KbZd4yH
Adobe and recent browsers no longer suports Flash PLayer. If anyone can post the video in other formats.
Hi @engenharia5EZVM9 ,
Click the right mouse button on load and select Delete:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Graphically one by one. In the load table you can use Shift or Ctrl buttons to select more than one row.
Roman Zhelezniak
