Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
How to fit final drawings to a page
7 REPLIES 7
Message 1 of 8
aliyuaziz
458 Views, 7 Replies
Please how do I fit final drawings as attached to a page. In other words how do I get a scale that will fit in the drawing.
Best regards,
Aliyu A. Aziz
7 REPLIES 7
Message 2 of 8
HoshangMustafa
in reply to: aliyuaziz
Hi
Please find the attached file.
Message 3 of 8
Youmay try this option:
Artur Kosakowski
Message 4 of 8
aliyuaziz
in reply to: HoshangMustafa
Thanks Mustafa,
The drawing I attached earlier is to the maximum scale 1:200, I am asking if there is a way to fit it even with an arbitary scale, say 1:233. Any ideas.
Best regards,
Aliyu A. Aziz
Message 5 of 8
Dear Artur,
Thanks for the illustration. My drawing size is about 44m wide and 38m height and the image I attached earlier is to the last scale 1:200. Is there a way to increase that scale?
Best regards,
Aliyu A. Aziz
Message 6 of 8
What happens with a drawing when you mark the fit check box next to the scale selection list?
Artur Kosakowski
Message 7 of 8
Dear Artur,
The drawing remains the same because it's already at the maximum fit i.e. 1:200.
Aliyu A. Aziz
Message 8 of 8
Thees values are hard coded so you cannot enter them manually. I haven't tested this solution but you may try the following steps:
1. Generate the drawing in Robot for larger paper size
2. Print it to pdf
3. Print pdf as fitted to the paper size you have got in reality.
Artur Kosakowski
