how to define Half-closed channel
3 REPLIES 3
mhafiz377
442 Views, 3 Replies
hi,
anyone have any idea how to define or select from default material Half-closed channel?
please, i need assist in this matter.
thanks.
Tags (1)
3 REPLIES 3
tony.ridley
in reply to: mhafiz377
Define or select material section?
mhafiz377
in reply to: tony.ridley
 define the new section which is half-closed channel. because in the user's guideline in http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-37C90ACA-0068-46B0-9CE2-76DEF8EED29-1630.htm there's a section half-closed channel.
Assuming that the steel design code formulas for solid channel and half-closed channels are the same (which I think is true) just assign your section a channel symbol available from the list of sections in the save to the user database dialog.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
