Discussion Groups
Robot Structural Analysis
Active Contributor
mhafiz377
how to define Half-closed channel
168 Views, 3 Replies
02-12-2013 07:24 PM
hi,
anyone have any idea how to define or select from default material Half-closed channel?
please, i need assist in this matter.
thanks.
Please use plain text.
Valued Mentor
tony.ridley
Re: how to define Half-closed channel
02-12-2013 09:01 PM in reply to: mhafiz377
Define or select material section?
Active Contributor
mhafiz377
02-12-2013 09:06 PM in reply to: tony.ridley
 define the new section which is half-closed channel. because in the user's guideline in http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-37C90ACA-0068-46B0-9CE2-76DEF8EED29-1630.htm there's a section half-closed channel.
Product Support
Artur.Kosakowski
02-12-2013 11:57 PM in reply to: mhafiz377
Assuming that the steel design code formulas for solid channel and half-closed channels are the same (which I think is true) just assign your section a channel symbol available from the list of sections in the save to the user database dialog.
Artur Kosakowski
