Discussion Groups
Robot Structural Analysis
Valued Contributor
huyxp
how to create an axis arch in robot
684 Views, 9 Replies
08-13-2012 09:43 PM
i don't know create a axis arch in robot?
please tutorial for me step by step create an axis arch in robot as show iamge below
Please use plain text.
Product Support
Artur.Kosakowski
Re: how to create an axis arch in robot
08-14-2012 12:14 AM in reply to: huyxp
See message 4 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Curve-fitting-panels-amp-auto-update-of-pane...
Mark the create bars check box if needed.
Artur Kosakowski
Valued Contributor
huyxp
08-14-2012 12:36 AM in reply to: huyxp
tks you
I want draw a beam arch or simple bar arch ???
Product Support
Artur.Kosakowski
08-14-2012 01:09 AM in reply to: huyxp
The bar type is the set of the parameters you want to use in the design modules of Robot. It is irrelevant for static calculations of the model itself.
Artur Kosakowski
Valued Contributor
huyxp
08-14-2012 01:18 AM in reply to: Artur.Kosakowski
hi tks you very much
can you tutorial as movie??
Product Support
Artur.Kosakowski
08-14-2012 01:34 AM in reply to: huyxp
Like clicking on 3 points that define an arch? :smileyhappy:
Artur Kosakowski
Valued Contributor
huyxp
08-15-2012 02:17 AM in reply to: huyxp
how to create truss arch as iamge below?
Product Support
Artur.Kosakowski
08-16-2012 12:06 AM in reply to: huyxp
Replace the top and bottom arch with lines from one bar intersection to another. Save the file as a dxf. Open it in Robot.
Artur Kosakowski
Valued Contributor
huyxp
08-16-2012 01:36 AM in reply to: huyxp
thank You very much
But I had a problem as image below
Product Support
Artur.Kosakowski
08-16-2012 02:34 AM in reply to: huyxp
Try to replace the arches in AutoCAD with lines from node to node.
Artur Kosakowski
