i don't know create a axis arch in robot?
please tutorial for me step by step create an axis arch in robot as show iamge below
See message 4 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Curve-fitting-panels-amp-auto-update-of-pane...
Mark the create bars check box if needed.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
The bar type is the set of the parameters you want to use in the design modules of Robot. It is irrelevant for static calculations of the model itself.
Replace the top and bottom arch with lines from one bar intersection to another. Save the file as a dxf. Open it in Robot.
Try to replace the arches in AutoCAD with lines from node to node.
