How to change colors used in legend
6 REPLIES 6
PatrickEC
1956 Views, 6 Replies
I am using 'Section - legend by colors' from the Display dialog. Is there a way to control the used colors, because as you can see in the picture by default Robot picked the same color for both materials.
6 REPLIES 6
I'm sorry but this currently cannot be done. I have added this request to the wish list.
Artur Kosakowski
susi33
in reply to: Artur.Kosakowski
Is this feature was added in latest version of ARSA?
Artur.Kosakowski
in reply to: susi33
No, there is not such possibility in Robot 2015.
Artur Kosakowski
zrilek
is it possible in ver. 2016 and 2017?
fpeyreH69L7
in reply to: zrilek
Dear Robot users,
I am interested in the solution of how is it possible to change the color in the legend of beam section.
Is there solution with version 16 ?
Thanks in advance,
Best regards,
Frédéric
JacquesGaudin
in reply to: PatrickEC
This can be done by editing the `color.ini` file in C:\Users\<username>\Appdata\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2019\CfgUsr.
You can choose 30 colors by changing the RGB values named AppSec1 to AppSec30 for the relevant display style.
Note to create a new display style, you also need to edit `font.ini` in the same folder. The files are read-only but this can be unticked in their properties.
Don't forget to back up the original before editing!
@PatrickEC  @fpeyreH69L7  @zrilek  @Artur.Kosakowski  @susi33
