Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
how to 3D rotate a building structure model
5 REPLIES 5
aarondariusvaz
1173 Views, 5 Replies
Dear sir/ maam how do i rotate in 3D when im using the building design project... I also wanted to know if chosen frame design project or shell design has the same effect and results as in chosing building project
5 REPLIES 5
Romanich
in reply to: aarondariusvaz
Hi, you can use SHIFT + RMB
or
or
or
*RMB - Right Mouse Button
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Š„Š¾Š±Š¾Ń‚ | App Store for Robot
Romanich
In Building Design:
Roman Zhelezniak
Thank you very much i overlooked the tab
Simau
in reply to: fayasfayas
Simau
Hi@fayasfayas
Ff the 8 supports are bolts, you may set them only as pinned.
