How do i change so Robot calculates after Eurocode 3 (offshore)? or is this the same as NS 1993-1:2005?
And is it possible to change parameters as gM1 from 1,25 to 1,3?
Solved by jad.dellel. Go to Solution.
Hi Mortel09!
You can change parametrs like this:
The english version of the capture:
Click to the "copy to the user's set" first to allow you to change from 1.25 to 1.30
