Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
hilda08
507 Views, 5 Replies
hollow slab
i changed my hollow slab to a bigger one, but when i did, the ratio for the beams got smaller. shouldent it be lagrer?
5 REPLIES 5
Rafal.Gaweda
in reply to: hilda08
It depends on stiffeness of whole this system. Play with different slab thicknesses \ beam sizes and look at results.
Rafal Gaweda
hilda08
in reply to: Rafal.Gaweda
i have to have a certian tickness of the slab, but i dont understand why the ratio of the beams got lower when then slab got bigger.
Rafal.Gaweda
Rafal Gaweda
jenyzosin
When the slab have a biger height, the rigidity of the slab is biger and the beams can't deform.
My advise is to create a thin slab (like 7 or 8 cm ) and the diference of weight (til 30 cm) you give as a surface load on slab. I use this metod when I want to increase the ratio for beams.
There's a fine line between genius and insanity. I have erased this line - O.L.
Artur.Kosakowski
Hilda,
Please check also:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/unrealistic-beams/m-p/3390693/
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Beam-offsets/m-p/3332921/
Hope this help you understand this situation even better.
Artur Kosakowski
