Discussion Groups
Robot Structural Analysis
New Member
JBogger
Hollow Sections Column-Beam Connections
5597 Views, 12 Replies
01-09-2012 04:58 PM
Is it possible to use a steel hollow section as the beam member when designing a column-beam connection in Robot Structural Analysis 2012 Pro?
According to online user guide (link below), hollow sections seem to only be available for column members of base connections.
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-435C42C0-C4E8-4970-B78E-A52E21B08C6-1058.htm
Any help is much appreicated,
Please use plain text.
Product Support
Artur.Kosakowski
Re: Hollow Sections Column-Beam Connections
01-10-2012 12:01 AM in reply to: JBogger
No, this is not possible. The easiest way of checking the available section types for particular connection is to check which of the parametric section icons are not grayed out as shown on the attached picture.
Artur Kosakowski
New Member
JBogger
01-10-2012 06:17 AM in reply to: Artur.Kosakowski
Hi Artur,
Thanks for getting back to me so quickly. That's a pity. Was hoping for some work around.
Possible future feature!
Thanks again,
James.
New Member
rokasnow
Re: Structure Design - Steel Design - Compound Members
08-08-2013 06:22 AM in reply to: JBogger
hello
I am interested in designing a steel connection with a double H profile. It's for a base column.
I don't have it available on robot, i can only design a I profile or a tube.
Neither the user defined compound won't work.
What should i do ?
Thank you
Ruxandra
New Member
rokasnow
08-08-2013 06:37 AM in reply to: Artur.Kosakowski
Hello
I need to calculate a base plate for a steel column a double HEB
It is not availabe in the section selection.
Is there any possibility to have this calcul done ?
Thank you
Product Support
Artur.Kosakowski
08-08-2013 08:04 AM in reply to: rokasnow
With such section not being supported you may try to use the user defined structural tube and stiffeners instead if this is acceptable for you.
Artur Kosakowski
Active Contributor
sampath.kumar
08-21-2013 04:54 AM in reply to: JBogger
I am looking for connection design for HSS column to W section BEam. However in the Robot I am not able to find the HSS section for column. I have attached screen shot of the database for columns available in Robot . So can you please help me out
Product Support
Artur.Kosakowski
08-21-2013 05:34 AM in reply to: sampath.kumar
For this connection type structural tubes are not supported.
Artur Kosakowski
Active Contributor
sampath.kumar
08-22-2013 09:51 PM in reply to: Artur.Kosakowski
Thank you fro the reply, but in our stores we work with same conditions. column (HSS) to Beam (Wsec). so can you plase let me know if in case we have to use HSS column do we have database fo rthe same in robot ? Thanks Sampath
Active Contributor
sampath.kumar
08-22-2013 11:05 PM in reply to: Artur.Kosakowski
I have attached scenorio for the HSS column to W Beam section. can you please help me out in steel connection for the same.
Sampath
