how can I do to select bar number and paste them in teh main window, as in the example below
Regards
Solved by FilipePagaimo. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
It's possible if you select the desired bars and click "Calc Note" make like example below:
