Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Help For Beginners
14 REPLIES 14
Message 1 of 15
toha_mh
1927 Views, 14 Replies
Help For Beginners
Hi Friends, I am a new user of Robot. I am finding too many problems here. I hope somebody can help.
1.When I want to draw a floor slab, if I draw differently (clockwise or anti-clockwise, starting from longer beam or shorter beam side) it shows different maps in stresses and moments. So what is the actual method? How should I draw?
2. There are too many options. Floor, Panel, Cladding ... Inside Floor there are Shell, Deck Slab (One way), ... If I want to draw a solid floor salb which one I should use? And when I should use the others?
3. How can I design T-Beams? I mean when I set code parameters, it says that T-Beam was considered, but doesn't show any reinforcement for flanges, only shows for webs.
4. Some times when designing required reinforcement in beams, it says that for certain  beam there is "insufficient capacity against shear". Why is it happening and how to solve it? (In the attachment beam no. 33 and 66)
5. In the attached file, I drew the edge columns aligning centers, without eccentricity. But as we know in reality, it will have to be constructed with 10 cm eccentricity (ei between the centers of col. no. 5 and 17). So how should I actually draw? If I draw with eccentricity, when designing the beams, it shows a message "Segmets of the length less than 10 cm have been removed, Transfer of the RC Element has been completed". What does this mean? Is this a problem? How to solve this?
Thanks In Advance.
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
in reply to: toha_mh
Your choice. For results presentation please set correct  \ desired Direction
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-16AA1074-A4F2-4EAA-A456-86AF1F396341.htm
Rafal Gaweda
Message 3 of 15
Rafal.Gaweda
Floor = slab :
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-316A5523-11CC-4857-B410-649A36B19A09.htm
in short : flat horizontal panel
If you want to use such panel \ floor in desing or get results use Shell.
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-13A7E8C9-AAB0-44CE-8C48-DC9BB38...
Rafal Gaweda
Message 4 of 15
Rafal.Gaweda
Additional settings you have to use:
flange.jpg:
Rafal Gaweda
Message 5 of 15
Rafal.Gaweda
Leave it as it is or use offsets.
But before take a look at these threads;
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Beam-offsets/m-p/3332921/highlight/true#M276...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Consequence-of-axis-position-offset-excentre...
Rafal Gaweda
Message 6 of 15
Rafal.Gaweda
It is caused by torsion. Turn it off.
Developers will check tosion design.
Rafal Gaweda
Message 7 of 15
Rafal.Gaweda
in reply to: Rafal.Gaweda
Please check your \ Robot calculations (below). Let us know if there is any bug in Robot.
Rafal Gaweda
Message 8 of 15
toha_mh
Thnx a lot. Now it's clear to me.
But can't ROBOT design ribbed (hollow block slab)? I see there is a tab called othographic, but even when I use that, it doesn't show the ribs in the panel thickness, or doesn't design the ribs.
Message 9 of 15
Artur.Kosakowski
Message 10 of 15
toha_mh
@ RG_Adsk, how can I turn tortion off, please?
Message 11 of 15
Romanich
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 12 of 15
ilianirosli8
How to turn it off?
Message 13 of 15
HI @ilianirosli8
What exactly you would like to turn off? Could you quote post and lines you are referring to?
Artur Kosakowski
Message 14 of 15
ztyjackson
in reply to: ilianirosli8
Switch layout to structural model-geometry, go to design tab, required reinforcement for beam/column-option, then code parameters...
I am in the same problem where it says "insufficient capacity against shear" but the problem was still there when torsion is turned off.
Message 15 of 15
Romanich
in reply to: ztyjackson
Hi @ztyjackson ,
It is hard to say what is the issue without having the model. You can zip and attach the model.
Roman Zhelezniak
