Hi Friends, I am a new user of Robot. I am finding too many problems here. I hope somebody can help.
1.When I want to draw a floor slab, if I draw differently (clockwise or anti-clockwise, starting from longer beam or shorter beam side) it shows different maps in stresses and moments. So what is the actual method? How should I draw?
2. There are too many options. Floor, Panel, Cladding ... Inside Floor there are Shell, Deck Slab (One way), ... If I want to draw a solid floor salb which one I should use? And when I should use the others?
3. How can I design T-Beams? I mean when I set code parameters, it says that T-Beam was considered, but doesn't show any reinforcement for flanges, only shows for webs.
4. Some times when designing required reinforcement in beams, it says that for certain beam there is "insufficient capacity against shear". Why is it happening and how to solve it? (In the attachment beam no. 33 and 66)
5. In the attached file, I drew the edge columns aligning centers, without eccentricity. But as we know in reality, it will have to be constructed with 10 cm eccentricity (ei between the centers of col. no. 5 and 17). So how should I actually draw? If I draw with eccentricity, when designing the beams, it shows a message "Segmets of the length less than 10 cm have been removed, Transfer of the RC Element has been completed". What does this mean? Is this a problem? How to solve this?
Thanks In Advance.
Solved by Rafal.Gaweda. Go to Solution.
Your choice. For results presentation please set correct \ desired Direction
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-16AA1074-A4F2-4EAA-A456-86AF1F396341.htm
Floor = slab :
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-316A5523-11CC-4857-B410-649A36B19A09.htm
in short : flat horizontal panel
If you want to use such panel \ floor in desing or get results use Shell.
Additional settings you have to use:
Leave it as it is or use offsets.
But before take a look at these threads;
It is caused by torsion. Turn it off.
Developers will check tosion design.
Please check your \ Robot calculations (below). Let us know if there is any bug in Robot.
Thnx a lot. Now it's clear to me.
But can't ROBOT design ribbed (hollow block slab)? I see there is a tab called othographic, but even when I use that, it doesn't show the ribs in the panel thickness, or doesn't design the ribs.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
What exactly you would like to turn off? Could you quote post and lines you are referring to?
Switch layout to structural model-geometry, go to design tab, required reinforcement for beam/column-option, then code parameters...
I am in the same problem where it says "insufficient capacity against shear" but the problem was still there when torsion is turned off.
Hi @ztyjackson ,
It is hard to say what is the issue without having the model. You can zip and attach the model.
Roman Zhelezniak
