Hi Arthu or Rafal, can you please help to sort out the instability of the problme i found when analyising a 7 pinned arch(see attached model and analysis and sketch). i released the joint in a similar way when I do analyze continoous beams with intermidate hinges. but in the case the software states INSTABILITY OF TYPE 1 OR 3. the structure i m anlyis is a hub Spoke bas . the structural behaviour is similar to the one of a bicycle wheel.
The source of error may be:
wrong release of Joints
wrong type of Anlasis,ie. linear- non linear analysis
Please give me or correct my analyis.
Thank you very much
I would model in one of these ways.
I think your model was unstable because it is 3D so your have to avoid global rotation around Y and then in some nodes to many releases.
Other point : you can't release all the bars in rotation when ending to a pinned support, at least one has to be not released in that dof.
One last point, except you have an horizontal bar to link both supports and avoid them from going in opposite direction, I would let the structure slide on one side to let it take it real deformed shape. (I put this also in the files as you can see the difference.)
Hi T Sautier
Thank you very much for your explanation
I will do the analysis again
