Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Having some trouble with the calculation
1 REPLY 1
joachn09
190 Views, 1 Reply
When I run the calculation I get a message that says " No convergence of nonlinare problems. Do you want to continue?" When I press "Yes" it starts calculating again, but the same message appears few minuttes later.
Does anybody know how to solve it or what it means?
1 REPLY 1
Artur.Kosakowski
in reply to: joachn09
This means that Robot is not able to find the solution for the non-linear analysis you defined. There may be a lot of reasons for this starting from ignored instability, excessive load value etc.
See e.g. http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Relaxation-with-robot/td-p/3416615
Please try to use the parameters as shown on the attached picture.
Artur Kosakowski
