mikibierzo1973
586 Views, 1 Reply
Harmonic Load
Hi!
1.-Is it possible to get the speed of the nodes in a harmonic load calculation?.
This is possible in the time histori analysis, but for the harmonic analysis this option remains off.
2.-How I can combine the charges if I have a Time Historty Analisys?
Example:     1: Dead weight
                   2: Weight Machine
                   3: Maintenance Charge
                   4: Dynamic loading machine (Time History Analysis)
Thank you for all
1 REPLY 1
It is not directly output in results of harmonic analysis but amplitudes of speed in harmonic analysis can be obtained from aplitudes of displacements (displayed in for instance Displacements table) . It is resulting from the first derivative of sinusoidal function. It is enough to multiply displacements by 2*Pi*f where f is the frequency of excitation.
Analogously amplitudes of acceleration can be obtained multiplying displacements by (2*Pi*f)^2
                   2: Weight Machine
First converting selected time steps of time history case into simple load cases and then combining them with other cases in combinations:
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
