I introduced the vibration of a machine (frequency=10Hz) : HARMONIC ANALYSIS.
The problem is that the results are not clear: there isn't load combinations with harmonic
Can you explain me this type of analysis
Best regards
Solved by Pawel.Pulak. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
I understand that with harmonis analysis we cannot generate automatic combinations, that's it?
so we do manuals comb
You can provided you assign the nature to the harmoinic case.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Why? It works for CM66, and most likely for all other codes.
I come to ask a question about the reactions caused by harmonic analysis, why the values are null?
As written by Rafal; add some load in case 21. You need to have some load that you want to apply in 'dynamic' way.
If you want to treat load defined in other load case as mass use the load to mass conversion. You can also use the added masses option if you want to add additional mass on the model.
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-FEC73829-9EDF-406B-9BAB-4A9201A32B0C.htm
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-293A6BC3-EBE2-480B-921C-55FE7FB9DE2C.htm
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-0F3E4B20-E266-4AFE-A7D8-12669751495B.htm
Hello Artur,
These loads are estimated based on equipments in the hangar? that's it?
I'm not sure if I understand the question. Which loads do you mean exactly?
This is the dynamic load you assume as changing value in time e.g. the moving / rotating part of an engine.
Iam sorry, i mean the specifications notes of this project
Thank you for all
Hello Arthur,
I have not found the value required for the harmonic load calculation, will I be able to change the type harmonic FRF ???
what is the difference between harmonic and harmonic FRF?
Thank you in advance
